I am attempting to replace the shift linkage on my '68 with a 4 speed Muncie. I ordered a kit from Volunteer Vette which indicates it is a complete shift linkage for a 64-68 Corvette. The problem is that the 1-2 shifter rod is about 3/4" shorter than the one on my car (the 3-4 rod is a little shorter too)and the shift levers are different (the rectangular holes which fit over the side cover are at different angles and the levers themselves are taller as well). In addition, the shift rods are bent slightly different from the ones on my car. The adjusting sleeve which goes on the 1-2 shifter rod is also shorter than mine which amplifies the fact that the rod itself is shorter.
I do not have the original tranny in my car. The main case is 3885010 with a code of P7T29, the tailhousing is 3857484 and the side cover is 3884685.
I have installed the locating gage and locked the shifter in neutral (and the transmission is in neutral as well) but I am not sure if my shifter rods are correct and the repops are incorrect or if my shifter rods are incorrect. I am wondering if having the wrong tranny in the car is the cause of the problem, although I doubt it.
Has any one had this problem and can lend some advice? I know I could return the linkage but I wanted to replace it new. All of the other Corvette parts vendors also list the same linkage for a 64-68 but I thought the shift levers were unique to 68. Thanks for any replies.
