Axle stud removal / installation - NCRS Discussion Boards
  • Rex T.
    • December 1, 1984
    • 455
    Is it possible to replace rear wheel studs on a 67 Corvette without removing the axle?
    Rex
  • Larry L.
    • May 31, 1993
    • 101
    Re: Axle stud removal / installation
    You have to remove the rotor.
    The answer is a definate yes I did it on my 65 coupe years ago. I used two flat washers, use a good wheel bearing lube on the studs, nut and washer, Use the existing nurrel - you can feel this when your rotate the stud. Goes in pretty easily. The lube prevents damage to threads on new stud.
    Have fun -
