67 Big Block w/AC drivers side horn mounting - NCRS Discussion Boards
  • joe aronne
    I have a 67 bb w/ac and a friend of mine disassembled the car when I got it so I could start to restore it. During the process I went to place the drivers side horn onto the radiator support and realized the horn did not fit. The condensor is an original GM sealed in a box dated 1969 and the radiator support is a replacement by coffman corvette. The bracket on the drivers side comes down above the middle of the bolt hole and the horn will not mount vertically. I did not remove it so I was wondering if anyone had a picture they could share with me.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67 Big Block w/AC drivers side horn mounting
    Look at the face of the inner fender. There should be a bracket riveted there.
    • joe aronne
      That is on the passengers side
      • Randy S.
        • January 1, 2003
        • 586
        Joe,
        I have a 66 small block with same issue. I have always assumed my condenser was incorrect (too wide)as it partially covered the mounting hole.I have seen others with a narrower condenser where the horn fits vertically. I ended up using the lower mounting hole on the condenser
        Randy
        • Randy S.
          • January 1, 2003
          • 586
          Joe,
          Check this out. many others in archives
          Randy
          • joe aronne
            Thank you
            • Wayne W.
              • April 30, 1982
              • 3605
              OOPs, Sorry I didnt read that very well.
