Muncie date code?? - NCRS Discussion Boards
Muncie date code??
  • Greg Janko
    Muncie date code??
    Please decode this mo/date/year. P0515 Thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: Muncie date code??
    What is the case casting number?
    Bill Clupper #618
    • Wayne M.
      • March 1, 1980
      • 6414
      Depends also on location of assy. stamp
      In addition to Bill C's post (which will enable to determine 1963 calendar year, 1964 & 1965, or 1966, depending on the maincase casting # (top line, passenger side), the location will differentiate between 1964 or 1965. If stamped onto the driver side shifter cover machined flange flat (lower right corner), it is 1964. If on the passenger vertical rear edge to the left of the filler plug, it is calendar 1965.
