Hello,
I recently purchased a matching number, 1968 Corvette 427/390HP 4-Speed, T-Top car. I would like to verfiy whether or not this car has a M-21 close ratio trans in it. On the side case I found a metal plate at the bottom with the numbers 3915090 on it. Also, I see a "S" stampled on the forward lower side of the case behind the bell housing. In addition, the casting # above the fill plug (no drain plug) is 3925660.
Thanks!
Joe
Thanks!
Joe
