C3 72 starter solanoid plastic color - NCRS Discussion Boards
  • Rob C.
    • August 31, 2004
    • 144
    Hi all,
    On a LT1 should the solanoid plastic be gray in color.
    Mine is black but I herd that it should be a gray plastic.
    Wich is right.
    Thank You,
    Rob
    Re: C3 72 starter solanoid plastic color
    Rob-----
    I'm not aware of any that were gray. Most likely, yours should be black. However, there were some very dark brown versions starting to be used about that time.
    • Rob C.
      • August 31, 2004
      • 144
      Joe,
      were the dark brown heavy duty?
        Rob-----
        They may have been, but I've seen them on a lot of solenoids without HD "credentials". To my knowledge, they began appearing about 1972 or 73.
        • Rob C.
          • August 31, 2004
          • 144
          Re: Thank You again Joe:) *NM*
