Original T3 Headlamps - NCRS Discussion Boards
  • Kirk McHugh
    I bought a set of old original T3 headlamps for my 1967 vert (327/300 auto with A/C. power steering, power brakes). Can I just unscrew the headlamp covers (4 screws I believe), remove the chrome rings (2 screws each) and switch out the bulbs? Or will I have to re-aim the lamps when done? Any suggestions would be appreciated. Thanks.
    As a sidebar, what do all of the numbers on the headlamp bulbs mean? There appear to be two sets of numbers in the back near the plugs, a set of numbers at 10:00 (two sets of numbers), 12:00 (single set of numbers), and 2:00 (USA & number). Seems like they should denote something, such as production year, etc.
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Original T3 Headlamps
    Kirk,
    Switch 'em out as suggested. Probaly won't need to aim them, especially if you only drive in the daylight hours......
    Here is everything you always wanted to know about T-3 headlights and more.....
