C2 steering wheel removal - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    My repro teak steering wheel cane in today for my '67 (I know it's not original equipment, but I don't like plastic). The service manual describes steering wheel removal for a wood wheel and a telescoping wheel--neither applicable here. Anyway, for one it says to remove the horn cap by simply pulling up, for the other it says to pry off the cap. Well, it doesn't simply pull off, so how do you pry it off without damaging something? Also, must I disconnect the harness at the bottom of the steering column, as the manual says? Can't I just disconnect the battery? Thanks.
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 steering wheel removal
    Larry,
    Looks like you have standard column.......the horn button is held on by spring-steel prongs, and should pull off by hand. No persuasion should be necessary. Remove retaining nut, then use a steering wheel puller, or homemade device, to pull wheel. No need to disconnect harness. No need to disconnect battery, either, unless your neighbors get pi**ed-off when you blow the horn while trying to remove the horn button.
    Joe
    • Larry S.
      • March 11, 2007
      • 457
      Joe, it won't pull off by hand, and I'm pretty strong. The cap will rotate maybe 5 degrees but won't pull off at any point. Help!
      • Stephen L.
        • May 31, 1984
        • 3148
        Pull harder!! Unless someone has bolted it in place the spring steel clips hold it.
        Once you get past that, there are some phillips screws to remove and the wheel is free. No need to remove the center bolt unless you want to also replace the hub.
        • Joe C.
          • August 31, 1999
          • 4598
          Yes, No Puller Needed! Yes, Pull Harder *NM*
          • Larry S.
            • March 11, 2007
            • 457
            Thanks, Steve--it worked! Hard to believe those little spring steel clips are that strong. The horn contact 'thingie' jumped out, but I finally figured out how it goes back in. The steering wheel looks 100% better! Thanks again for the advice.
            • Larry S.
              • March 11, 2007
              • 457
              Re: Yes, No Puller Needed! Yes, Pull Harder
              I did pull harder and it worked! Thanks so much, Joe.
