88 Air Diverter - NCRS Discussion Boards
88 Air Diverter
  • Bill B.
    • September 30, 2002
    • 351
    88 Air Diverter
    Just finishing lots of repairs on my 88 convert project. I have one issue left. The air diverter is missing both solenoids. Suspect they need vac too but no vac lines anywhere? I do have a blue and a green pigtail connector(s)hanging near. My questions are as follows:
    #1-which pigtail goes on the left(green?) and the right (blue?)
    #2-if the solenoids need vac what does the vac line routing look like and originates from where (bottom of Throttle Body or rear vac ports or does it matter)?
  • Tom S.
    • March 1, 2004
    • 1087
    Re: 88 Air Diverter
    Bill
    I have an 88 vert, if you can tell me where the air diverter is located I will look at mine and tell what you need to know.I do not know what the air diverter is, I have to confess I don't know much about newer cars. But I will be glad to help.Tom
    • Bill B.
      • 351
      Re: 88 Air Diverter
      Well, I call it the air diverter? Located on passenger side front engine top. It is connected by metal pipe that runs to the air pump on the driver side. Driver side is left side for my connector question. The connectors probably connect to the top side of the diverter unit and I am guessing they have a vac line running to them. Suspect the vac line is a small plastic setup? If you can help me on this I can take her for first test drive, state inspect and then I can paint her! Tom, any help appreciated.
      • Tom S.
        • March 1, 2004
        • 1087
        Re: 88 Air Diverter
        Bill I found 2 lines coming off the air pump,1 is a small steeline and the other is a steel line that goes into a rubber hose. i don't know if that is any help or not I do not see any electric lines down there at all. Keep trying we will get it! Tom
        • Bill B.
          • 351
          Re: 88 Air Diverter
          Tom, I will take a picture of things on mine and then maybe we can make sure we on identical sheets. With your help I will get there. May not be able to do until tomorrow.
          • Tom S.
            • March 1, 2004
            • 1087
            Re: 88 Air Diverter
            Bill
            That would be a big help to me if you could take a picture,I will be glad to help you. Tom
