BIg Block Aluminum Component Casting Dates
  • Gregory M.
    • June 1, 1984
    • 172
    Where are the casting dates on big block aluminum components, like intake and heads, and are they stamped or cast?
    I was under the impression that intakes, for example, had a casting date which was cast at the foundry, not stamped, and visable rom above...but I am told the components cast by Winters foundry have a date stamped on bottom and no casting date on top.
    I also thought cast iron heads had a casting date cast at foundry and visable from above with valve cover removed...what about the Winters aluminum heads? If it is year specific what about 1968-69? Thanks again.
    GM
  • William C.
    • June 1, 1975
    • 6037
    Re: BIg Block Aluminum Component Casting Dates
    They are cast, and generally are located in places not viewable without disassembly, The Aluminum Heads do have a casting date in the Rocker area, all years. The Intakes are generally dated on the bottom of the manifold.
    Bill Clupper #618
    • Mark #28455
      aren't heads dated on underside?
      Aren't the aluminum heads dated on the underside of the intake ports?
      • Wayne M.
        • March 1, 1980
        • 6414
        Yes, and are visible with a mirrror after ....
        the intake is removed. At least this is the case with "842" heads.
        • William C.
          • June 1, 1975
          • 6037
          Yes, my mistake, thinking Iron. *NM*
          Bill Clupper #618
