I have the oil pan off of my 67 327/300 for a cam swap, and I plan to replace the rear main crankshaft seal while I have access to it.
Is there a "best" quality part for this or should I just use a generic replacement? I'd like to use a high quality part so that I don't have to go in there again.
Also, I note that the Paragon catalog lists a "first design, narrow" and a "second design, wide" seal for the small block. I presume that the second design is superior and that both versions fit. Is that correct?
Lastly, I have heard that some people recommend installing the seal slightly rotated (about 1/8 inch), so that the joints between the two seal halfs do not line up exactly with the joints between the bearing cap and the block. Is this a good practice?
Any advice would be most appreciated.
