Woohooo cleaning my office
Re: Woohooo cleaning my office
A good, cheap shortcut is to buy a scanner that has a removable slide carrier as part of the assembly. You can then load two to four slides at a time and scan them thereby making jpegs on the spot. From there you can print them out or bring the electonic files to Walmart on a memory stick and get your favorites printed out on real photo paper. You can do the same with 35mm negatives. The scanner has the ability to handle both negative and positive images.- Top
