I just had my 67 L79 rebuilt and it runs great, sounds great, but I have to much oil pressure in my opinion. When I fist start it up under fast idle the oil pressure gauge is pegged past 60 pounds. When the oil finally gets hot it pretty much stays at 60 pounds while cruising. I read that 45 pounds is where the gauge should be at 2000 rpms.
I am contemplating removing the oil pan and changing out the pump that the builder put in there. I have a faint oil leak now that looks like it is coming from around the rear main seal. The motor has approximately 400 miles on it since it has been rebuilt. Should I put more miles on it and see if it gets better or try and nip a problem in the bud before it gets worse?
