1962 BW transmission speedo gear housing - NCRS Discussion Boards
  • lonnie johnson
    Does the tab that holds the speedometer driven gear housing in place in one of these T-10s go straight into the flat in the housing, or does the side of the tab slip into the housing slot? It's a mighty hard place to see and work with in the car!!
    Lonnie
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1962 BW transmission speedo gear housing
    narrow(width) end of the rectangular piece of stamped steel goes in the driven gear housing. mike
    • Terry D.
      • May 31, 1987
      • 2690
      What Mike said! *NM*
      • lonnie johnson
        Thanks guys, sort of what seemed correct to me.
        Lonnie
