63 engine bay - NCRS Discussion Boards
63 engine bay
  • Rainer S.
    • May 31, 2003
    • 468
    63 engine bay
    When routing the wire harness and overflow tank hose along the RH inner fender well, does the wire harness and the rubber hose have their separate plastic loops, or are they held in the same clips ?
    Also, I understand, the early (Dec 62) build cards, had the wire harness routed inside (closer to center of car)the hood brace. Is the same true for the overflow hose ? The sketch in the IM shows the hose going on outside (closer to the outer fender)the hood brace.
    Could someone clarify, or post pic ?
    Rainer
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: 63 engine bay
    Rainer,
    This is a picture a 63 engine bay and you can see the wire harness and expansion tank hose routing on the pass side. There are also pictures in the Dobbins book if you have one.
    • Jerry S.
      • May 31, 2003
      • 145
      Re: 63 engine bay
      I don't know much about the fine points of original cars. All three of my 63's have the hoses behind the hood support.
      • Chris Patrick
        Re: 63 engine bay
        Tim, if you copy the Direct Link for Layouts
        and put it in the Optional Image URL below, it will show up like this.
        This one is a bit large, but it gives very nice detail. Of course, you have to be ready for the nitpicking about your car, like there is no shielding, the passenger wiper is missing, and so on. Gasp, is the windshield missing???
        The easiest way is to claim it is a photo you have from a show or picked off of ebay or something.
        • Rainer S.
          • May 31, 2003
          • 468
          Re: 63 engine bay
          It apears to me, that the wire harness and the overflow hose have their own respective clip, as seen in front of the alternator, correct ?
          Also, will check, if I have the "Dobbins" book. I thought' I had all ther pertinent books for C-2 Corvettes.
          Rainer
          • Rainer S.
            • May 31, 2003
            • 468
            Re: 63 engine bay
            Thanks everyone. Tim, I found my Dobbins book, must have read it 3 times before, but was not looking for specific detail then. It will stay on my coffee table for a while, has a lot of 63 details in it, good pic's always help.
            Also, making good use of other books, specially Nolan's.
            Rainer
