I was wondering how to go about removing scratches from a black base coat clear coat that is the original paint? I can't tell if it's only in the clear or if it's thru the paint to the primer. All I can say is that you can catch them with your fingernail and that they are fine and white and really stick out against the black paint! One spot looks like someone dragged a box across the trunk and then turned it around and pushed it some more the other way so if that's the case I wouldn't think it would be past the clear but what do I know?
So what do you think...white scratches in a factory black base,coat clear-coat...will they buff out?
Greg Linton
#45455
Greg Linton
#45455
