Hoping to save myself from shelling out the big bucks for a Dewitts type of radiator, I purchased an after market brass radiator from my very reputable radiator shop.
Here are the issues I encountered.
1) My original aluminum Harrison is 16-1/2" tall from the top row of passes to the bottom. The new is 16" What happens is by missing that extra 1/2" in height, it forces the radiator mounting bracket to angle downward causing it to want to pop off when snugged up to the support. When I re-mounted my Harrison the problem went away as that extra 1/2" allowed the bracket to pull straight across to the core support locking it snug in place. Also, the new radiator would not properly mate up to the lower foam seals creating an air gap.
2) The mounting ear on the top of the radiator is at least double the width necessary for the rubber cushion in the bracket to slip over. What happens with this, is that this extra wide ear hits both outter edges of the bracket also contibuting to the bracket and rubber cushion popping off the radiator's ear.
This morning I returned to the radiator shop with both radiators and the core support and expalain the situation to the Gent who wanted his "hot shot" custom radiator tech to take a look at.
Of course my word of caution was to not mess around with my core support and not to screw up my Harrison radiator.
For those of you who tout the top sheld radiator vendors and avoiding these types of issues that's all fine and good and in my instance it drives that point home. I'm not providing this to receive lectures on woulda coulda shoulda, just trying to educate future radiator buyers as to the on-going pitfalls of the aftermarket world.
I'll keep you posted and P.S. to Joe Lucia, the core support wasn't mis-shaped after all.
Chuck
Chuck
