66 Protecto Plate - Additional Question - NCRS Discussion Boards
  • Kenneth A.
    • February 1, 2006
    • 64
    To the right of the axle number is an F what does this signify. Above it is an H which right of the VIN.
    Thanks for the help
  • Pat M.
    • April 1, 2006
    • 1575
    Re: 66 Protecto Plate - Additional Question
    Kenneth - I believe that in 1970, the last digit of the axle number code represented the plant that produced the differential. The H to the right of the VIN would represent the carburetor source, i.e., a Holly carb. I would assume these locations would be the same for a 66 POP, but I'm not sure.
    Patrick Moresi, #45881
    • Pat M.
      • April 1, 2006
      • 1575
      Kenneth - I may have misunderstood where you stated the F was located. If it's right under the H (and not a part of the axle code), this location may represent the month your car was built. It does for 1970, but in that year this figure was a number, not a letter. Check your assembly manual for your year - it'll decode all of these figures.
      Patrick Moresi #45881
      • Mark G.
        • March 1, 2001
        • 227
        Kenneth & Patrick -
        It is the "Vehicle Build Month Code" and "F" translates to October.
        Aug. 1965 D
        Sept.- U
        Oct.- F
        Nov.- Q
        Dec.- C
        Jan. 1966 H
        Feb.- B
        Mar.- M
        Apr.- E
        May - J
        June - G
        July - A
        My '66 coupes' POP has an "F" code and was built 10/21/65. The character location chart is in the Corvette information package available through GM; the codes are in the Assembly Manual.
        Mark #35760
