I have checked the archives an see multiple references to Duke W.'s "3 pints for the Muncie trans and 3.7 pints for the diff".
But my '65 Owners manual and shop manual call for 2.5 pints for the 4-sp trans.
Chilton's '63-72 Repair & Tune-up guide shows Trans at 2.5 up to 1965; then 3.0 pints thru '72. Can it be that the case volume changed from the 3831704 ('63-only) and 3851325 ('64 and '65 cases) when the '66-67 3885010 case and the subsequent "660" and "661" cases were used ?
With the differential, all sources point to 3.7 pints up to the end of model year 1968; then 4.0 pints is shown in the Chilton's source up to 1972. [I don't have '67-up GM capacity sources to X-check].
Also, I see that GL5 gear lubes may contain sulfur-based compounds to meet the "EP" extreme pressure requirements of the differental hypoid gears, but some say never to use these in our beloved Muncies, as the brass synchro rings will be attacked. Opinions ?
