I need to rivet the windshield washer reservoir bracket onto the drivers side fender well. Can someone tell the location ie. 3" from top of fender and 4" from side of fender. thanks
64 Windshield Washer Reservoir Bracket
Re: 64 Windshield Washer Reservoir Bracket
Here is the location of the top inner (nearest to engine)rivet.
6 1/8 inches from bottom gutter of fender (the step down area)measured along the inner fender
10 7/8 from the outside fender bonding strip, again measured along the inner fender.
Measured along the inner fender means I held the tape flat against the inner fender! the bracket appears to be parallel to the fender gutter line.
This is for a Mar64 car only, can not say if others are the same, however I bet GM marked the panels to aid production, therefore the location must be close.
have fun- Top
