Who has upper and lower a arm bushings for a C2 that will pass flight judging?Thanks!!!
Who has best C2 a arm bushings?
Re: Who has best C2 a arm bushings?
i've installed moog and the complete kit from paragon---moog shows deterioration in less than a year with a car with 55 miles on it---the 2nd car was fitted with paragon bushings which are 30 days old installed so ? nothing yet---installation was the same---fit was the same---i would lok at cost being the deciding factor---good luck,phil- Top
Re: gmpartsdirect.com part#401267
Rob-----
GM #401267 is not exactly correct for a C2, but it is 100% functional. This is the UPPER a-arm bushing and it lacks the "exposed rubber" on the inner end. Reproductions of the original style bushing are available from a variety of Corvette parts suppliers. The GM #401267 is correct for 1973-82 Corvettes.
The LOWER bushing, GM #3714368, is exactly the same as original.In Appreciation of John Hinckley- Top
