67 SB with C-60 - NCRS Discussion Boards
67 SB with C-60
  • Dale S.
    • November 12, 2007
    • 1224
    67 SB with C-60
    I am routing the positive battery cable on my 67. I go to the AIM in the back under battery cables C-60. My car has no evidence of ever having all the battery cable clips shown in the AIM. I have the 2 on the left by the starter and the one up on the flat area behind the distributer. The next 2 are shown one on top of the other. I have the lower one for the ground cable. I also do not have the one behind the battery. These clips are riveted on and I have no holes in my firewall. Is this unusual? Kent what do you have? This is an original March 30th car. Thanks in advance Dale
  • Kirk McHugh
    Re: 67 SB with C-60
    Dale,
    White convertible 327/300hp with AC, power steering, power brakes, 16,469 with a build date of April 18th. I have all of the clips shown in the aim riveted to the firewall.
    • Dale S.
      • November 12, 2007
      • 1224
      Re: 67 SB with C-60
      Anyone else with a C-60 with or with out the battery clips? Dale
      • Ray G.
        • May 31, 1986
        • 1187
        Re: 67 SB with C-60
        Hello;
        '22684 vert. 350 hp P.S. A/C
        Negative;
        Under str. column 1 1/2" toward the center of car.
        Positive;
        Left of Master Cyl.1" beneath.
        Straight behind left valve cover on the horizontal.
        Straight behind rt Valve cover on the vertical.
        Hope that helps.
        Ray
        I hope you dance
        • Kent K.
          • December 1, 1982
          • 1139
          Re: 67 SB with C-60
          Dale - The battery cable clips on the firewall of my mid-production run '67 are exactly as shown on page C60-E3 of the AIM.
          Kent
          NCM Founder - Member #718
          • Kent K.
            • December 1, 1982
            • 1139
            You have mail
            Dale - I emailed a tracing to you of the upper part of my alternator brace as you were asking about it in an earlier post.
            Kent Keech
            Kent
            • Dale S.
              • November 12, 2007
              • 1224
              Re: You have mail
              Thanks to all on the battery cable clips. The two under the steering column one for negitive and the one above it for positive( as per the AIM) are there but hidden. The one behind the battery was never there as there is no clip or hole for the rivet or rivet that held the broken off clip. Must have been missed. A special thanks to Kent Keech for his drawing of the alternator brace on a 67 SB C-60. Thanks to all who helped. Dale
