I've seen in earlier discussion threads that both the sides and bottoms of a radiator support for a c3 (1969) small block can be shimmed. I think that the bottom of mine needs to be shimmed, but I can't find shims for the bottom mounting bolts at any of the regular vendors. They all only seem to sell shims for the sides, which are too small to fit the bottom bolts.
I believe that the bottoms need to be shimmed because the fan shroud sits too low and pinches the lower radiator hose. The previous owner cut a piece out of the shroud to accommodate the hose, but I've got a new shroud and want it to fit correctly. I don't know what happened to the old shims. They weren't there when I took it apart.
Thanks for your help.
