63 radio speaker - NCRS Discussion Boards
63 radio speaker
  • Rainer S.
    • May 31, 2003
    • 468
    63 radio speaker
    I was checking my original speaker to see if it still works before re-installation. Found, that the the speaker membrane is totally dried-out. Breaks by minimal contact.
    I know, speakers are no rocket science,but my question is:
    Can the speaker be restored, namely re-using the frame etc and replacing the bad membrane and related items?
    When the speaker is mounted, one can only see the bottom, but not the actual membrane.
    I will post pictures in a few min.
    Any suggestions ?
  • Rainer S.
    • May 31, 2003
    • 468
    Re: 63 radio speaker
    Sorry for getting the posts out of sequence.
    If you look close on the face pi's, you can see the split in the membrane. I just barely touched it...
    Hope it can be repaired.
    Rainer
      Rainer-----
      Speakers can be re-coned. There are many sources for such work. Do an internet search and you'll likely find plenty. Usually, the material used for re-coning is much better than that used originally. So, you end up with a better sounding and more durable speaker.
      • William C.
        • May 31, 1975
        • 6037
        I have used Jackson Speaker service in the past, I got them out of "Hemmings" in the "Services" section. An internet search for "Speaker Recone" should provide multiple options.
        Bill Clupper #618
        • Rainer S.
          • May 31, 2003
          • 468
          Thanks Joe and Bill. Did a search, found Jackson and others. Will give Jackson a call.
          Rainer
