C2 Door Panel Chrome Screws - NCRS Discussion Boards
  • Alan Drake
    Would like to replace the chrome screws that hold my 64 door panels on, however the repro's are not correct. The orignal ones (#9417987) appear to have a head size of 5/16 (.306) and lenght of .875.
    While the repro's are smaller with a head size of .260 (a #6 metic?) and lenght of .775 The repro's also come with the cone shaped washer attached which I believe is not correct and therefore would need to be removed if they were to be used.
    Anyone know a source for correct 5/16 chrome screws?
  • Dick G.
    • May 31, 1988
    • 681
    Re: C2 Door Panel Chrome Screws
    I need this info. also. Have you tried LICS? DG
    • Wayne P.
      • August 31, 1975
      • 1025
      The factory used number 8 screws with a number 6 head. This has a special name which I can't remember. Speciality fastner places usually carry these.
      • Alan Drake
        pn# 9417987 HELP
        My original chrome door screws are #8 head & screw. The repro's from LI are the #6 head with #8 screw shaft, (also has the chrome cone washer attached) With a little luck somebody can look up the pn and it may have a spec with it (I do not a any ref material on these).
        Appears we may have some disagreements on these screws. SOoo, all I can say for sure is that these scews have been on my car since the spring of 1966. Now people have made the point before that the original owner (Mar64 - Apr66) could have changed all twenty chrome screws with 20 new chrome #8 screws, but . . .
        Another point, the 64 door panel (and the few 63 ones I have seen) uses the chrome cone washer (not correct name) to secure the vinyl to the cardboard backing. Said cone is a #8 size! The cone on the repro screws are #6.
        What do the door panel repro dealers do? We may have two different door panels.
        Shades of the 63/64 SHP star washer on fuel filter bracket.
          Re: pn# 9417987 HELP
          Alan-----
          These screws were never a SERVICE-available part and, in this particular case, I can't otherwise find any information on them.
          • Alan Drake
            Thanks Joe *NM*
