C3 - Seatbelt Comfort Clip - NCRS Discussion Boards
  • Raymond W.
    • September 30, 2003
    • 248
    Is anyone familar with these GM's Comfort Clips? This plastic devise slides on the seatbelt shoulder strap, allowing the passenger to adjust the tension of the upper shoulder strap. I've seen some clips that consist of two pieces. The piece that fits inside the back part of the clip, looks like
    (I I I) three vertical slats about 3/8" wide, connected across the top and bottom by a thin piece of plastic. Use of these clips, with or without this additional piece made no difference in the sliding capability on the belt. Is the clip that was used on a '74, one piece or does it include the 2nd piece? Thanks.
