I have a 67 L79 engine. Are there quidelines for the placement of the valve cover decals?
Tripoli's Chassis Restoration Guide show a one inch chassis stencil for a 69 and a 7/8 in. stencil for a 57. The example for the 65 seems to be a little bit larger than the 3/4 in. stencil I received from Quanta. Is the Quanta stencil acceptable? The original gas tank stencil on my 67 was 1 in. high. The stencil I received from LIC was 3/4 in. high. I purchased a set of correct stencils at a hardware store. Just wondering if I have to do it again.
Is the positraction differential tag supposed to loosely fit around the plug?
Thank you,
Randy
Thank you,
Randy
