OT: Repeat but still funny..... - NCRS Discussion Boards
  • Myron Sleeva
    Tool Definitions
    DRILL PRESS: A tall upright machine useful for suddenly ******ing flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
    WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses in about the time it takes you to say, "Ouch...."
    ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
    FLASHLIGHT: A convenient place to store dead batteries.
    CHRISTMAS PRESENT DRILL BITS: Used to set off the smoke detector when drilling any wood in the house.
    PLIERS: Used to round off bolt heads.
    VISE-GRIPS: Also used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. With a single click, have been known to raise an instantaneous purple colored blood blister.
    HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    AVIATION METAL SNIPS: See hacksaw.
    OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16" or 1/2" socket you've been searching for the last 15 minutes.
    HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
    EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle.
    TWEEZERS: A tool for removing the wood splinters left from the fir 2X4.
    PHONE: Tool for calling your neighbours to see if he has another hydraulic floor jack.
    SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog **** off your boot.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
    TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
    CRAFTSMAN 1/2" x 16" SCREWDRIVER: A large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
    TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over-tightened 58 years ago by someone at GM, and neatly rounds off their heads.
    PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a part.
    HOSE CUTTER: A tool used to cut hoses too short.
    HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
    MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
    ELECTRIC LAWN MOWER: A somewhat cumbersome device used to divide a long electric cord into more manageable lengths.
    DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
  • Rob A.
    • December 1, 1991
    • 2126
    Re: OT: Repeat but still funny.....
    I thought I'd use my drill press all the time...turns out I've used it more often for putting additional holes in the kids' belts than any other purpose.
