C3 crankcase vent tube - NCRS Discussion Boards
  • Al Lucero
    Hello guys....
    Question....were the steel crankcase vent tubes painted engine color? I have a suspicion they were. Mine still has a bit on it.
    I'm pretty sure I have the part name right, but it's the steel tube from the right valve cover to the air cleaner assembly connect via a small-cut rubber hose.
    Thanks!
    Al
    • 11608
    Re: C3 crankcase vent tube
    What year??? I suspect that may make a lot of difference.
    If I'm guessing the part correctly, you can see that mine has no paint.
    Patrick
      Al, a good rule of thumb is to look in the Assembly Instruction Manual (AIM) and if you see the item listed by PN for installation onto the engine then it was installed on the St. Louis final assy line. That means it wasn't present at the engine plant to 'catch' Chevy orange paint!
      GM tried to move as many engine 'accessory' parts down stream to the final assy plant as possible since that minimized inter-plant transportation and inter-division profit elimination on the company books. So, things like starters, carbs, alternators, Etc. were not with the engines when they were assembled...
      • Tom R.
        • June 30, 1993
        • 4081
        Re: 1975 crankcase vent tube
        I believe Al is referring to a 75 which was last year for the cowl induction style air cleaner. I don't believe it used the full metal elbow like the later C3 years
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Dick W.
          • 10483
          Unpainted
          Dick Whittington
          • Al Lucero
            Thanks all. I am working on/detailing my '75 and it's a late build - 26th from the end. It is the CI hood and air cleaner assembly. I don't know how that paint got on there and it's near the top of the tube too. At any rate, I guess I'll leave it just as it is.
            Thanks, once again, for all your help.
            Al
              Al -
              I'd remove any paint that's on the tube - the paint doesn't belong there, as the tube wasn't present when the engine was painted.
              • Al Lucero
                Thanks John. Will do. I'll clean it up a bit too.
                Al
                • KEN BUTCHER
                  std 350-305 CHEVY used the same vent tube as 75' *NM*
