'69 feat heat wave - NCRS Discussion Boards
'69 feat heat wave
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12695
    '69 feat heat wave
    Hi all,
    I still have one more annoying problem with my '69 BB conv. The drivers section feet area is getting unacceptably hot (especially during warm days) while the passenger side is ok. I've checked for air flows through the firewall but it is only appearing when the blower is switched on.
    If the hot air source is generated by the blower I would expect both sides to be hot and I should be able to cool the air using the temperature control wheel but this doesn't help out...
    HELP!!!
    Rob.
    Rob.
    NCRS Software Developer
  • Ralph S.
    • February 1, 1985
    • 935
    Re: '69 feat heat wave
    install a manual water shut off valve in the small heater hose and you will see a big difference in the passenger compartment comfort.
