I'm getting ready to install an AC Delco #15680264 (CT24RG) throwout bearing in my 66 big block and I noticed that the bearing collar which the fork retaining clips snap into is not perfectly round as on the bearing I removed. A portion of the circumference of the bearing collar has two relatively flat surfaces that form a rounded point. (This is hard to describe) I asume this "pointed" portion of the collar allows for easier attachment of the fork. Should the "point" face toward the fork or away from the fork?
I also note that the aft lip of the bearing collar (faces toward back of car)is quite thin, possibly 1/2 the material thickness (guessing) as compared to the old bearing, does this sound correct? Is it possible I have a defective "new" bearing?
Appreciate any thoughts from those having experience with these bearings. Thanks everyone for your ideas.
Rich
Rich
