76 green on green - NCRS Discussion Boards
76 green on green
  • joe
    76 green on green
    I own a 76 L82 dark green corvette with a blue/green interior, i was wondering if anyone knew how many cars were built with this color combination? I looked in the corvette black book for the amount and the only thing it tells you is the amount of green car built that year.
  • Robert C.
    • December 1, 1993
    • 1153
    Re: 76 green on green
    There were 5 interior color codes. The only guess-t-mate you can do is divide 5 into the 2038 green cars produced. Combo's of exterior/interiors weren't kept.
    Texas Chapter NCRS
    • Dale Weaver
      Acually acording to the info i got on,,,,,vettenet.com,,,there were 8 coler's in 76,check out vettenet.com joe,i found some pretty good info on my recently perchased 76 and i ran across an option that the owner must not have known . I got to looking and i thought what a funky suspention ,Then after checking closer i realized the car has the suspention that was only instaled on less than 5000 76 vette's,Can anybody tell me about this suspentioned ,Even if it is not a real good suspentioned it still should up the value of the car just becouse so few where made is that correct ?My hood had L-48 emblem's , does that have anything to do with the moter or is that the body stile ,I still need to run the serial# on my engine and see what i got,Thank's all ,Dale
      • Robert C.
        • December 1, 1993
        • 1153
        Dale, You may have the FE7 gymkhana suspention. It would consist of a larger front sway bar, stiffer front spring, and a 7 leaf rear spring. L-48 is the 180 hp base engine.
        Texas Chapter NCRS
        • Jeff nelson
          FYI-- The L-48 emblem is not original equipment on the 76 but an after market stick on.
