Re: C2 rear noise - NCRS Discussion Boards
Re: C2 rear noise
  • Rob A.
    • December 1, 1991
    • 2126
    Re: C2 rear noise
    James,
    Put your car uphill, even just the incline of a driveway will work. When you start out, if you hear a clunk just below you, it's probably the differential mount. If you decide that's it, you can remove the bolt and nut and install a new mount without removing the driveshaft.
