I went to change the oil in my newly acquired 1968 435hp coupe. The manual says crankcase capacity is 5 quarts plus one quart for filter. So after I change the oil I start the car and the oil pressure guage is nearly pegged on 70lbs...I run it a few minutes, shut it down, and then check the dipstick and I am a quart over...wtf?
So I call a buddy, whose opinion I value, and he says the higher oil pressure will not hurt and when the car gets hot the oil pressure will come down. So I idle it for a while and then take it for a spin. When warm, and at idle, the oil pressure comes down to 50-55sh but pegs on 70 with a little rpm. Then it starts pushing a little oil out the rear of the valve cover gaskets on both sides. Do I dump a quart of oil or change my valve cover gaskets?
GM
GM
