67 tri power ? - NCRS Discussion Boards
67 tri power ?
  • Will Gage
    67 tri power ?
    I am trying to identify a tri power setup that is supposed to be from a 67 vette L71 427. I need casting numbers for the intake and carbs or some other way to see if this thing is legit. The intake is aluminum and the air cleaner is triangular.
  • Geoff C.
    • May 31, 1979
    • 1613
    What reference book did you consult? *NM*
    • Joel Falk
      Re: 67 tri power ?
      The intake is casting number 3894374. The end carbs have list number 3659, center carb 3660.
      Look for the date code on the carbs to ensure it is a '67 carb as these were used for several years and also available as service replacements
