Rear Window defogger - NCRS Discussion Boards
  • roberto gutierrez
    I have a '73 vette and want to install a rear window defogger; however, the assembly manual indicates that I have to drill a huge hole in the left rear wheel well so that I may place the shield to the defogger motor. Does anyone know if this is correct? Can anyone email me a picture? Also where can I buy a sheild for the defogger motor? I live in southern California so any reference would be appriciated.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Rear Window defogger
    I have seen one installed and it does require a shield in the wheel well. It also requires special rear interior trim on coupes. I have no pictures of the shield and the setup for convertibles is lots different from the coupe instalation.
    Lyle
    Lyle
    • Gregory M.
      • May 31, 1984
      • 178
      I have a 1968 coupe with a rear window defroster...if it would help I can take some pics for you of the drives side rear fender area where the motor and duct are located...not sure what shield you are talking about...let me know.
      GM
      • Harmon C.
        • August 31, 1994
        • 3228
        Greg
        Look in the wheelwell under the motor on the outside near the top of the tire and their should be a plate or cover. It may be blacked out but that is the shield in question.
        Lyle
        Lyle
