70 Battery Cable Replacement (+) - NCRS Discussion Boards
  • Jeph South
  • Bill Clupper
    Re: 70 Battery Cable Replacement (+)
    Jeph, try a heat lamp to soften the grommet and make it more pliable. The plant generally used a soap solution for lubricant
    • Jeph South
      That was the Trick!
      After being heated, it was almost too easy! Thanks. I wish I had tried that in the beginning.
