FI fuel meter question - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    There is a 7017360 fuel unit on Ebay with a fuel meter number 7014781.
    I can't find an application for that number fuel meter.
    Can someone tell me where that fuel meter is used.
    Thanks, Bruce B.
  • John D.
    • December 1, 1979
    • 5507
    Re: FI fuel meter question
    Barry, That part number is ONLY for the main diaphragm cover. That same part number was used from mid 57 to 65. It's the round cover on top of the fuel meter bowl. Typically it has a brass fitting that screws into it.
    Most 62 fuel meters do not have a number stamped on the side of them. But if you refer to the NCRS pocked spec guide or judging manual for 62 you will see that some of them used left over L59-62 fuel meter bowls that are stamped 252.
    Recap: side of 62's bowls either no number or a few with 252's. Send us the ebay number. I saw a 61 for sale going for big buks. You should have bought those two outside the gate in Knoxville. hee I don't think either of us will ever forget that day. John D. P.S. I need a 902 fuel meter body real bad.
    • Bruce B.
      • May 31, 1996
      • 2930
      John, the unit is a 62 360 with dist Ebay # 190119728557.
      It is for sale by Jere Stahn, the header guy in York, PA.
      What do you think?
      Bruce B.
