Just a note to inquire about a ground strap that is on my 63 FI car that is a FEb-Mar car. Engine build date is 2-11. Ground strap I am referring to is the one connected to the acclerator lever. The wide wide strap.
The aims does not show any type washer for this strap. Refer to Sect U65 Sheet 5.00 titled Radio-ground straps. Bottom right hand corner. Says ground strap held on with screw. Doesn't say anything about an outside star washer being used. I realize and can plainly see that in other instances on this page the ground straps have the "typical" star washer. In these cases the assembly procedure is a 121763 star washer, strap, and then the screw. But to repeat the wide ground strap for the accelerator lever does not use this. Now maybe St. Louis didn't follow this. I don't know. Your thoughts please.
Meanwhile I have no idea in the world what the judging manual says on this subject. Just referring to the AIMS for my source for this instance. Thanks, John
