1961 exhaust tips - NCRS Discussion Boards
1961 exhaust tips
  • Terry T.
    • January 1, 2005
    • 13
    1961 exhaust tips
    We're just finishing a 61, and we've been told that the tips of the stock system we recently purchased are supposed to be sawed off in order to make the opening rouchly parallel to the ground. I think they are like that on 1962, but I haven't found any authority indicating they should be like that on a 1961. Help?
  • William C.
    • May 31, 1975
    • 6037
    Re: 1961 exhaust tips
    Firstly, the 1961 and 1962 rear pipes are identical part numbers, so will be identical in appearance. Secondly, the correct configurstion is more complex than you suggest, as the outlet is actually flared outward in a specific configuration. I would strongly suggest that you familiarize yourself with an original pipe prior to trying to duplicate the appearance. If you need help, email me and I'll take a photo of an NOS pipe end for your reference.
    Bill Clupper #618
    • Terry T.
      • January 1, 2005
      • 13
      Thanks for the timely response. And, if you would be so kind as to take a photo, I would be most appreciative. I've been poring through the books, and I just can find any pictures.
