MY DRIVER SIDE TURN SIGNAL LIGHTS BLINK MUCH SLOWER THAN MY PASSENGER SIDE TURN SIGNAL LIGHTS. I THINK THERE IS A SWITCH UNDER THE DASH THAT MY BE DEFECTIVE. AM I ON THE CORRECT PATH? IF SO IS THERE A PART#?? ECKLER'S???
1967 SIGNAL LIGHTS
Re: 1967 SIGNAL LIGHTS
Ed - Not sure what switch you are referring to, but if one side operates differently than the other, you might want to look at the bulbs, sockets, wiring, grounding, etc because there is only one turn signal flasher and unless the turn signal switch is broken both sides should flash at the same rate. Is there any problem with the blinking rate of the lamps when you operate the hazard flashers? Personally, I'd look for a poor ground. I'm sure you'll get some other input on this. Good luck. Pete- Top
Ed,
Check your turn signal-parking lamp bulbs. Be sure they are per the owner's manual, otherwise, you'll get faster/slower blinking rates. Sorry, I'm not very adept at remembering the proper lamp numbers. I'm sure there are many posts in the archives regarding this subject.
Please turn off your caps lock. With all capitals, it's like shouting.
Kent KeechKent
NCM Founder - Member #718- Top
