softtop is not closing well. - NCRS Discussion Boards
  • Twan B.
    • June 30, 2005
    • 207
    A few years ago i restored my softtop and now i've got the "problem" that when i close the door the vent window post get pushed out side (less then half an inch). All seals are new!
    Is my problem usual, has anyone the same problem????
    Twan #44079
  • Twan B.
    • June 30, 2005
    • 207
    Re: softtop is not closing well.
    I've just now put some vasaline (grease) on the upper weather strips and it give some result. Is this normal to do this?
    Twan #44079
    • Bob R.
      • June 30, 2002
      • 1595
      I can't answer your question on fixing the problem. However the vasaline will over time cause damage to the weather strip. Use something with no petroleum base in it.
