I love it when I post all at once. Next question. I'm having some minor brake problems. The brakes are pulling slightly to one side, and when I apply more than light pressure I get the brake warning light. I've bled the brakes and found that two are sucking a lot of air, hence part of the problem, I know. I plan on repairing or replacing the system this winter to eliminate this problem. My dilema, should I have my calipers, etc. rebuilt, or do I replace them with new o-ring style and SS lines. If I do the later, what kind of a hit am I going to take at a NCRS judging event. The car is a top flight winner now as an unrestored car, and I plan on restoring it to top fligh standards wherever possible.
1972 brake question
Re: 1972 brake question
You have several options. One is having your calipers rebuilt, costs extra to get your calipers back. Two is exchanging calipers with a vendor, you can get standard or o ring pistons, your choice. I would go with the standard steel lines and not take any points hit. You will not take any flight points deduction with either of the caliper choices.Dick Whittington- Top
Right front and left rear.Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.- Top
Your brake system is not working correctly. What good are matching numbers if you can't stop? I would check the rotor runout and get it to .002 or less, check the bearing endplay as well- I set them to .0015-.002" with the rotors corrected,if needed, then address the calipers. If they are not SS lined then get a set. If the run out and endplay is correct you don't need O ring calipers.
Good luck
Gary- Top
