'64 ammeter
  • Don B.
    • May 12, 2008
    • 132
    #1
    '64 ammeter
    I'm trying to identify how the ammeter is actually connected in my '64 coupe. The wiring diagram in my Assembly Instruction Manual seems to have a problem since both wires (blk/wht & blk) go to +12v on the diagram. Both of the two wires from the ammeter go through the right hand firewall connector. The B/W goes to the horn relay where a lot of red wires are connected together (+12v distribution) and the black wire goes to the battery terminal on the starter solenoid according to this diagram. There must be a mistake somewhere.
    TNX Don
  • Donald O.
    • June 1, 1990
    • 1564
    Re: '64 ammeter
    No there's no mistake in the diagrams, its just not a true "amp meter", but rather a voltage differential meter. The very small difference in the two voltages indicate whether it is charging or discharging.
    don
      • 15229
      Re: '64 ammeter
      I've got a good paper on that. Send me an e-mail.
      • Don B.
        • May 12, 2008
        • 132
        Re: '64 ammeter
        GM Donald -
        If the meter is a differential voltmeter, it must be a sensitive one measuring millivolts. The wire sizes are substantial between where the voltages are sampled. However, this would certainly explain my confusion.
        TNx, Don
        • Donald O.
          • June 1, 1990
          • 1564
          Re: '64 ammeter
          Is that paper OK to post here?
          • Bud K.
            • August 1, 2005
            • 60
            Re: '64 ammeter
            I'd like to second that Duke. It would be helpful to the rest of us 64 owners to have access to some more information. Thanks in advance.
            Bud.
              • 15229
              Re: '64 ammeter
              I don't see why not, but the diagrams embedded in the MS Word file won't come through, so that may limit its value. You can try if you like.
              I didn't write it, and I forgot who sent it to me.
