A while back I took apart the dash in order to replace the speedo needle, cable and a non working speaker on my '71. When I went to put the dash back in, my tach and speedo lights no longer worked. Looks like I messed up a ground wire somewhere as I can get the lights to work when I turn the light switch on and ground each of the lights housing to the chassis using a separate wire.
There is a ground on the left side above the kick panel with two black wires and they look to be OK. I also noticed that each of the tach and speedo have a ground wire that clip onto the back of the speedo and tach each. I tried to ground those wires separately, but nothin happened.
How do I trace or figure out which ground wire is the one that I messed up. Can anyone help me go through this systematically? I'm lost!!!!
Thanks.
Thanks.
