What is the correct orientaion of the horns on a 57? Is the rim surface of the horn part at about a 30 degree angle pointed up to the centerline of the vehicle?
C1, 57 horn orientation
Re: C1, 57 horn orientation
339 is rh horn and 340 is lh. The L mount brackets are mounted with the base at the top and bolt to the radiator core support. Horns are over fiberglass not over the radiator. Hope this helps. Gary....NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
