66 427/425 TI Ignition Loses fire When Warm - NCRS Discussion Boards
  • Tom C.
    • November 1, 1997
    • 94
    I just installed a restored (by Fiedler)TI Distributor and system. The car runs great for 30 minutes or so or until warm and will just "quit" no fire. After it sits for a few minutes it will fire up again and run for who knows how long. Should I start with a replacement ignition switch and bypass the firewall wiring system? The coil is a correct replacement but made in China! Any ideas on troubleshooting on this problem?
    Call Dave...
    He's a stand-up guy who stands behind his products and is known to bend over backwards to help fellow Corvette enthusiasts with TI problems.
    • Tom C.
      • November 1, 1997
      • 94
      Re: Rick Snow
      Seems to me that I've seen some postings on this subject from Rick Snow. Anyone know how to get in touch with him?
        From your copy of Driveline magazine...
        TI Specialty
        1631 Pheasant Run
        Richmond, IN 47374
        Owner: Dave Fiedler (765) 962-4265
        • Bill S.
          • January 31, 2007
          • 396
          Re: From your copy of Driveline magazine...
          i would start with the coil. it is the most vulnerable to heat. i had a 64 impala that did this 35 yrs ago and it was the coil. the amp is way out front and should not get hot. also make sure you do not have a ballast resister on it.
          • Richard S.
            • November 1, 1994
            • 809
            Re: 66 427/425 TI Ignition Loses fire When Warm
            Tom,
            Could be a number of issues. The more information you post regarding the details of how and exactly when the engine stops....the easier it is for the experienced guys here on the Board to suggest possible fixes. Duke Williams and others really helped me out with my ignition problems. Let me know if you need more from me....the archives have some good posts.
            regards,
            Rick.
              Here's a stab in the dark... When TI first made its debut, there was a service bulletin regarding the use of the radio RF suppression capacitor on the ignition coil. Apparently, it would charge up over time (engine run time) and result in the distortion of the waveform to the TI system's signal amplifier resulting in ignition performance problems. The advice given was to delete or NOT install this coil capacitor...
              While the AIM books do NOT distinguish between standard and transistorized ignition engines regarding the use of this capacitor, some year specific JG books tell you the coil capacitor was NOT installed on TI based cars. If you've got the radio RF capacitor installed on your car, it's a pretty quick test/fix to remove it and see if that makes a difference...
