72 LT-1 - NCRS Discussion Boards
72 LT-1
  • Mike G.
    • July 31, 2002
    • 709
    72 LT-1
    i am looking at a 72 lt1. the block is correct but i am not sure about the heads. did the 72 lt1 use double hump heads? the marking on the heads on the car looks like the top of a crown with 3 points. correct?
    Re: 72 LT-1
    m.-------
    1970 was the last use for the cylinder head "double hump" casting symbol. 1971-72 LT-1 (as well as many other applications) used a casting symbol that I would describe as a triangle with a "chopped off" top, otherwise known as a trapezoid.
    • Mike G.
      • July 31, 2002
      • 709
      Re: 72 LT-1
      does it have 3 points on top?
        Re: 72 LT-1
        m-----
        I suppose it could be described as having 3 points on the top.
        • Mike G.
          • July 31, 2002
          • 709
          Re: 72 LT-1
          can i send you a pic?
          mgreene@crawford.com
          • Mike G.
            • July 31, 2002
            • 709
            Re: 72 LT-1
            a better way to describe it is a triangle with 2 steps on one side. do the 71 72 base 350 heads have the same markings as the lt1 heads?
            • Harmon C.
              • August 31, 1994
              • 3228
              Re: 72 LT-1
              The 73 L-82 has what I call three pointed mountains like you describe but I do not know if it was used in 72.
              Lyle
              Lyle
              • KEN BUTCHER
                Re: 72 LT-1
                Hey M., why don't you just take the valve-covers off and get the casting numbers and build dates and that should answer your questions.
                Ken.
                • Bryan K. Montford
                  Re: 72 LT-1
                  You should be able to look thru the oil fill hole on the driverside to see a casting number, date code and the guide plates.
                  Bryan
