Is there a correct repro. '67 redline available ? - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1187
    Hello;
    I was told at the Rochester Regional the Coker Firestone SS red lines are the incorrect logo/script.(6 points)
    Your thoughts on a correct redline?
    Ray
    I hope you dance
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Is there a correct repro. '67 redline availabl
    all reproductions will receive point deductions
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Ray G.
      • May 31, 1986
      • 1187
      Re: understood. Looking 4 the most correct *NM*
      I hope you dance
      • Dick W.
        • 10483
        The Kelsey Goodyears are by far the closest.
        Dick Whittington
        • Joe C.
          • August 31, 1999
          • 4598
          Ray,
          Goodyear Power Cushion is as close as you'll get. It should be dead nuts on except for the DOT markings.
          Goodyear red and/or gold sidewall tires are actually 1/2" wider (approx.) in tread width than similarly BRANDED whitewalls. Joe Kelsey has been selling them for years and, AFAIK, they have been acknowledged by most black hats as being the best available.
          Firestone branded their red/goldlines as "Super Sports", NOT Deluxe Champions like the whites. Firestone supposedly destroyed the original tooling for the (also, 1/2" wider tread)original issue SS tires. Firestone Super Sports have only started being reproduced again about 2 years ago. Up until then, Coker was selling Firestone Deluxe Champion red/goldlines, which never were installed on Corvettes.
          Whitewalls are another matter altogether, and the choices are much wider, as Goodyear, Goodrich, Firestone, Uniroyal all make fairly true, and relatively equally faithful reproductions. The 1965-1967 7.75-15 red/goldlines were especially made for Corvettes only, and were constructed from a different carcass, with 1/2" wider tread. 1968 was the first year that bias belted ("wide oval") F70-15's were used.
          Joe
          • Clem Z.
            • January 1, 2006
            • 9427
            a corvette owner here in western PA paid $15K for 5 new original red lines,no rims. do you want me to check and see if he has a line on any more????
            • Ray G.
              • May 31, 1986
              • 1187
              Re: Thank you everyone. $15K ? unwilling/unable. *NM*
              I hope you dance
              • Gregory M.
                • May 31, 1984
                • 178
                I am contemplating flight judging for the first time adn have a question. How much of a point deduction will result from a "correct" repop bias ply with a DOT marking? Is it a full deduction, as though you had a radial tire on the car? Thanks
                GM
                • Joe C.
                  • August 31, 1999
                  • 4598
                  Greg,
                  NCRS Judging Reference Manual, page 21,: Tires
                  "Deduct 10% - Reproduction OEM brand and size tires which differ from original only because of Federally required DOT markings."
                  Joe
                  BTW: The above referenced book is available on this website, and should be a valuable resource for you, along with your TIM&JG, Shop Manual(s), AIM, etc.
                  • Gregory M.
                    • May 31, 1984
                    • 178
                    Joe,
                    Thanks for the heads up...I have the tech. guide but not the judging mmanual...I have to get one...
                    GM
