I am putting a Pertronix electronic ignition kit in my '65. In order to get the gap between the magnet ring and the ignitor module (which should be between and 0.010 and 0.060") you need to install washers here and there, per the instructions.
Problem is that I will need to put a shim between the gear and the distrib. housing. To do so you need to remove that pressed-in pin just below the gear. How on earth do you get that thing out ? I've trying punching it out easy and as hard as I could bring myself to do (in fear of breaking the thing). Any ideas ?
Thanks, Mark
Thanks, Mark
